I just spent yesterday installing the four Moog CA's, alignment, and then later changed out the front carrier. The Moog UCA boots are a decent looking black boot now, one was already installed, and the other pushed on securely. The pair I have that the boots are falling apart, they are a slight green color I believe, those even the upper thick mounting edge is cracked a lot. The uppers are very easy to replace the boot, if one is available that fits well.
I had a noise Friday that I took to be one axle(oldest, CV boot dry rotting, warranted), changed that and the noise went away for three days. Then changing the four CA's really brought it back, awful grinding/popping/catching, slow and at speed. The carrier was toast, I haven't opened it up yet, but the pinion yoke moves around a bunch in multiple directions. I need to learn how to build those front D35's, I need three done now.
