ron_toolman
- November 29, 2006
- Ford Ranger
Hi ....... had a busted line, replaced that and also a new caliper . I blead all lines and master cylinder, also lines going to ABS module no air at all ..... full pedal. Then when started the pedal drops to the floor as if it's full of air. replaced master cylinder, good uded one, same thing. Now they tell me it's the booster, but I tool the two lines off the master and made short 3" crimped ends and re-started vehicle, pedal now does not go to floor. So that would tell me the booster is ok ? ........ Haynes book says if the master ever gets are in it, it has to be hooked to a scanner to bleed all lines properly ..... called ford dealer and they say nope ... bleed as you usual. Any ideas ? ........ Appreciate any help.
