Bazz270
- April 14, 2020
- Haifa,Israel
- Ford Explorer 2007 XLT
What power switch you are going to use?
Three contact pins in power switches are : 12v inlet ,12v outlet and ground pin.
Usually you should connect 4x4 module side brown wire to your power switch inlet,then outlet wire goes to 12v relay "control voltage" pin.
Connect any 12v ACC to relay power pin and dont forget ground pin also
Then connect your " accessory " relay pin to Transfer case side brown wire.
All the 12v wires should be protected with suitable automotive fuse housing.
You should check it first with electrician..i am an a mechanic so maybe i am wrong here..
Use only automotive industrial grade splicing crimp (or another ) sleeves and heat shrink insulation.
