Explodr94
- March 29, 2006
- Vista, CA
- 1996 XL
Last weekend, put in new bearings and races. Wheels felt nice and tight up and down. When I grabbed the tire from side to side I noticed that there was a lot of play. I did not put the car down and check the tie rods properly, but will do that. However, when I did the same check on the driver side, I noticed that the steering gear had a lot of play and I am starting to think that is the issue, not tie rods. On my friend's old corvette you can adjust the play on the steering gear. The gear box on the ex looks like it has an adjusting nut, but I could not find an adjustment procedure in the Haynes manual. Can you adjust the steering play on a 94 ex? And what is the procedure?
