JasonF
- May 27, 2002
- 2004 XLT 4x4 4.0
My 96's control trac has always worked as advertised. Of course, it has been since last winter since the 4wd was used much. I switch it into low occasionally to keep things moving, but the auto4wd should require no maintenance. Today I was at a stop sign on a slippery hill so I put the auto 4wd on instead of regular 2wd. She kicked in and went but then appeared to stay hard locked into 4wd as I slowed down 100ft later and went to make a left turn. I had to actually decrease my rate of turn and switch back to 2wd as I could feel the drivetrain binding up. It did this a second time so now I am convinced I have a problem. Also, it will not engage auto unless I am stopped. Did one of my speed sensors go out? Any ideas on why the electronic clutch would just lock in and not sense slippage and engage like it is supposed to? What can I do to fix?
Thanks
Jason
Thanks
Jason
