natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
My concern:
I see fresh coolant "seeping" from the upper transmission cooler line going into the radiator.
From everything I read on here, the ATF pressure should be high enough that if the radiator tank (or gasket?) were to break the barrier between coolant and ATF lines that ATF would seep into the coolant, not the other way around. Also, from what I can tell, my fluids are not contaminated in any way. Getting everything up to temperature, the oil is a dark brown with no bubbles or grey/white color, the trans dipstick is a clear red, and the coolant in the overflow and cap is a clear green.
What is going on? The other day I wiped the area in question down and since then have driven it once. On the lip right below the fitting, there's green fluid. Looking up from that, the only area it could have come from is the trans fitting which is also wet. I will get a picture and/or video tomorrow when it's daylight but I'm rather curious on people's opinions on this. I do know that the trans line leaving the radiator goes to another cooler (aftermarket?) and then back to the trans. I've been thinking about bypassing the radiator but I'm not sure if the other cooler is large enough for the trans.
