Nbarlow
- August 22, 2015
- Omaha NE
- 2003 Mercury Mountaineer
I have a 2003 Mountaineer and the drivers side window will not go up. I took the door part and used a test light to test the power connections. The white with black wire is up and I think it was pink with blue is down. The white with black wire isn't getting any power at the switch to at the motor and the pink with blue is getting power at both. All other windows in the car work from their door switch as well as the master switch. Can someone please help me figure out what to try next?
Thank you
Thank you
