Nevea'sExplorer
- June 30, 2006
- Pittsfield, Ma
- 02 4.0 XLT 4x4 5R55W 3.55
I looked around and couldn't find my problem or even figure out what you would call it. But when my truck is running in park and I turn on my rear window defroster my truck beeps a couple of times while unlocking the drivers side door and turning on the interior lights, but if I'm driving everything still happens except the interior don't turn on. My buddy mentioned something that there may be a body control module but in my search I came across a ton of BCM's and none seemed to have been what I was looking for.
Also when I turn off my truck my door lock on the drivers side switch is fully functional until I pull the key out of the ignition then all the other door lock switches will work except the driver side's switch. I changed the switch out twice once with an aftermarket switch and then one from ford. I know all the wiring in the door is good I've had it all fixed.
Any ideas? I'm sure it's quite possible that the two problems could be caused by the same defective part.
