Same problem - with a twist!
Folks,
Up until a month ago I had a 4.0 SOHC X that performed really well, smooth to drive, oodles of power. I then had it converted to run dual fuel to try and save a few quid on Petrol. She now has both a Petrol system and an LPG (Liquid Petroleum Gas) fuel system. Problem is, you've guessed it, having spent nearly £2500 on the fuel system conversion the car now drives like a dog! The twist is only when running on LPG, on Petrol she runs (pretty much) as well as I remember previously.
The problem I have is the same as you guys, poor response to throttle depression. Pulling away from a standstill the rpm drops, the truck shakes a bit and then pulls away. Sometimes, depending on engine temperature, the drop in RPM will result in a stall. Similarly, in the cruise, if you put your foot down hard the power doesn't come in (no kickdown) and generally engine response/power is rubbish.
She's been back to the converter twice who has fiddled with the ECU mappings (I have a CEL on by the way) and lastly replaced the IAV but the problem is still there with poor power take-up.
What I don''t understand, and maybe this will help with the diagnosis, is that on Petrol she runs OK, why do I only get these problems which sound sensor related when I run on gas - given the petrol system uses the self same sensors!!????
Any clues gratefully received as usual.
Good luck to everyone with this problem, it's a real pig isn't it!!!
Thanks,
- Andy.
