jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
Nothing extra is needed besides 90+ and it will run on cheap gas but you just wont have the performance and or it may knock under heavy loads.I would keep them.also I wouldnt worry about the increase effecting the rings or anything. Only thing that will really effect all that is just mileage or poor oiling or cheap oil.run full synthetic and your bottom and should be good for another 500k if they are in good shape now.
Did you make sure to drain the lifters after cleaning and pump back up with good oil? You have to take the top plunger off and use the spray straw from a spray bottle, little red straw (like from brake cleaner or carb cleaner) and push down in the middle of the lifter with the top plunger off.I would do this then submerge in oil and do the same thing wile in oil (messy I know) this will make sure good clean oil is in them.if not cleaner will not compress like oil, may feel stiff but basically is a dead lifter once extreme pressure is put on it..
