Experience trans shop said NOT to change fluid @ 100k?! | Ford Explorer Forums - Serious Explorations
SgKukov
CT
2003 XLT 4.0
Hey Guys,
i figured now was a good time to get my tranny fluid changed, i have tomorrow off and called a local very reputable shop to setup an appointment.
After i told the guy the specs and mileage he said not to do a flush and recommended against even changing it! He said with the mercon 5 full synthetic it wasnt really neccassary.
My trans seems to be shifting a tiny bit clunkier lately as i go through the gears, i thought changing the fluid might help... he says its not a big deal and not to worry.
What do ya'll think?
Change the fluid and filter. That old nasty worn out fluid won't be helping you. Synthetic or not, transmissions break down the fluid over time and shed wear particles from friction materials and other wear points.
I just changed mine. The sad excuse of a dealership didn't dare to change the filter though. They just flushed it out.
What did I get out of it? - a brand-new car, no tranny slip, better acceleration (still wouldn't dare to challenge the kids on the drag strip though) and 1 mile extra on the gallon.
Anybody not convinced? I am! imp
After seeing the crud in some cars' trans pans, I never let fluid go beyond 20k miles on my vehicles. Fluid and filter change are a lot cheaper than a trans rebuild. I have added drain plugs to all my trans pans so it's a quick job.
Have you any that are without a fill tube/dipstick, like 5R55S? I fitted mine up with a fill tube and dipstick, pics and all, somewhere else in this dang forum. Maybe you can find it, if you care to look. imp
No, haven't had one without a fill tube.
On both my A4LDs, I replaced the drain plug I installed with a valve type plug, like is commonly used for oil drain plugs. Fumoto makes a nice example of this but I use the parts store special. So far there are no leaks and I can open the valve to drain some or all of the fluid without any mess.
5R55S fill tube/dipstick
I think this is the one you're referring to: Transmission Fluid on 05 explorer starting with post #7
