rocket 5979
Resident Gearhead
- April 22, 2002
- Lake Villa, Illinois
- '03 XLT 4.6
Probably right. I don't think the stock bottom end on a 4700 pound vehicle can handle more than that range. Especially if it has a 6r80 with no trans tuning or valve body work.
Mine makes 400 to the rollers at 5psi so his should be higher...until it dies!
Well the stock 4.6 bottom end in these trucks can only take about 450rwhp before they give up the ghost. Most keep it to less than 400 just to play it safe. So as long as the power is kept within check then all should be well. I don't have much experience with the newer Explorers with the 6 speed auto transmissions. Can they not be tuned yet? I just assumed that by now the TCM would have been able to be accessed to allow full recalibration. With the newer electronic transmissions it is not nearly as necessary to modify the valve body to allow for more durability with added power since there is an absolute vast amount of settings that can be modified in the tune to modify the way clutches are applied to allow for holding more power. But on the flip side of that coin, if the transmission is not tuned correctly then it can also grenade at power levels much lower than its hardware would have otherwise been able to hold. Now of course once you exceed the hardware limitations then now matter how good the tune is you will still break. That was one of the main reasons why I ditched the 5R55W transmission in my 2003 Explorer and went with a standalone controlled built 4R70W so that it could take some very serious abuse. I am curious to see what the limitation of the hardware is for the Ford 6 speed transmissions in the Explorers.
