182RG
- May 9, 2011
- Winchester, VA
- '11 XLT / '13 Touareg TDI
The factory battery failed during this cold snap. It made it not quite 4 year. All in all, not a bad performance.
I took it in to the local battery distributor to get a replacement. He remarked that Ford undersized these batteries, given the engine, and electrical accessory load on this vehicle. The stock battery was rated at 550 CCA, which is pretty weak in colder climates.
Most specs on-line read like this:
To start a 4-cylinder gasoline engine, you will need approximately 600-700 CCA; 6-cylinder gasoline engine, 700-800 CCA; 8-cylinder gasoline engine, 750-850 CCA; 3-cylinder diesel engine, 600-700 CCA; 4-cylinder diesel engine, 700-800 CCA; and 8-cylinder diesel engine, 800-1200 CCA.
I replaced it with an 800 CCA battery.
