rpr
- January 22, 2002
- Smith Mountain Lake, VA
- 2006 Limited
I had to mount 1/2" MDF adapters on top of the stock plastic speaker mounts to get enough room for my 6.5" Alpines to fit in the door panel. They still barely fit, and the rear of the magnets are maybe only 1/8" away from the metal door panel.
The speakers are really pushing against the stock thin plastic (somewhat stretchable) liner that exists over the door panel in this area. This thin liner is not flush against the metal door panel in this area, they kind of span the recessed metal in this area of the door. There is a perforation around this portion of the liner that will easily allow you to remove a 6"x8" section of this door liner.
Should I remove it? Is this 6"x8" section of the liner in this area necessary for acoustics or weatherproofing?
