Scott,
First off zip it back up, that's a mental picture I don't need Dead Link Removed
You helped me make my point. Quote: "even a moron could establish that the Ford Explorer does not have an optimized exhaust system." That, my friend, was my very first point. When you have the restrictions we are talking about, you do very little to improve performance by changing mufflers. Think of a series of about 6 tight kinks in a hose. The water isn't going to flow out of the end of the hose by undoing the last kink, is it? How about adding a section of sewer hose to the end? Think that will make the water flow any better through all the kinks? Well that is what you would have us believe with regards to an exhaust system...
As for my muffler comparo, again, I was offering information. It may not make a bit of difference on the explorer if you use a flowmaster or a Dynomax race magnum (I hold it will NOT...) But just because you can't use the info you think I should not share it? I was perfectly clear in establishing that this was on a modified system. I also felt I was clear on establishing that unless you have an optimized system it doesn't really make that big of a difference. Didn't I tell him to focus on SOUND? Man you keep making my points for me, maybe we really do agree but we just can't see it...
Now on to the benefits of FLOW. An engine is an air pump. The more air you can pump through the more power you make. Period. Now, with that being said, I will acknowledge that you have to actually match all your components to work with one another. Mismatched components cause the performance loss, NOT the fact that something has superior flow characteristics. You may have a discernable shift in your tq/hp curves, but more flow will make more power. I will give you the low end thing in this forum, you don't really want to build an engine that flows well at higher rpms because it might very well shift the tq curve up out of what your truck is geared for. The trick there is VELOCITY. Maximize the flow, but keep the velocity up. You'll have gobs and gobs of bottom end as well as something that will flow well and make good power.
As for "stick with Explorer info or don't bother?" Puh-leez! Do you think all the research I have done is so narrow as to only include 302's or 351's in Mustangs? Most of the stuff I have learned has come from experiences with all sorts of stuff; including turbo'd 530cid aircraft engines and ski boats with small block chevies. Engine theory is universal man, the sooner you learn that the better off you'll be. If I had dismissed everything I saw the Chevy guys doing because it wasn't on a Mustang I would still be going slow Dead Link Removed
Okay, here's the rundown on my 351:
I currently run 10.8:1 cr, achieved using 64cc chambered heads and custom flat top pistons that actually come up OUT of the deck. This winter the heads come off for some port "modifications" Dead Link Removed and decking to reduce the chamber volume and increase CR a little more to closer to 11 or 11.2:1. And that is with iron heads, not aluminum. Aluminum headed motors can run more compression because aluminum dissipates heat, effectively killing a good half point of cr. Iron keeps the heat in, and heat in the combustion chamber equals power. If you want to know why I went about it this way it was to achieve more compression while still allowing good flame front travel (instead of having to go over a big dome) and maintain good squelch characteristics. I use iron Dart heads and can still run on pump gas (I've had to drive it with 87 before, yikes!)
If you want to know more about my 351, feel free to ask. I'd be glad to share, I don't claim to know everything but am always happy to pass on what I do know.
Later, Rob
no Explorers, but plenty of Fords:
'82 Mustang GT 351W
'82 F250 351W
'91 Mustang LX 5.0
'78 Mustang II pro street
