my white eddie
- January 2, 2013
- Mansfield, Ohio
- 1997 Explorer EB-now 4X4
So far what I discovered is the u-joint listed in the 4406 swap thread
does not seem to fit the front pinion yoke exactly right. It was nice and
tight between the 2 outer stops on the pinion yoke when originally installed,
but somehow it had side to side slop between the pinion yoke stops when
I pried it back and forth with a large screwdriver last night. My thinking is
that the font joint is off center when tightened down due the extra space
causing the vibration. For right now I just pulled the shaft and it is smooth as glass. I will hit the u-joint section at work Sunday with a mic and see if I
can find one that fits between the pinion yoke stops a little tighter and if
it works I will throw out a part #.
