cmccul002
- March 29, 2008
- Ranger 94
Its me again, lol.
I have a 1994 2.3L. Broke down 2 weeks ago, come to find out the timing belt broke. i replaced it, and got it all back together and it started.
For the two weeks after that, it was rough getting it started sometimes. You would have to pump the gas and sometimes hold it down. Cranked for 10-15 seconds but it would eventually start. Sometimes it wouldn't, but if you let it sit for a few minutes it would eventually. I thought it was getting flooded.
Today, came out of work, and wouldnt start. Waited awile, it sounded like it wanted to, it was kicking over a little bit, but nothing. Now it wont even do that, just cranks.
I sprayed some starting fluid in, but nothing.
It is getting spark, I pulled a spark plug ( it has 2 per cylinder) and plugs looked clean. I had someone crank it without the plug to see if it was sparking and it was. AND, when it cranked some combustion came out the plug hole since there was one on the other side.
So it seems like that cylinder is firing anyway. Im stumped.
Any help is greatly appreciated.
