MikeTEC
- February 17, 2001
- Central Texas
- 2004 Mountaineer 4.6L
Just finished a Mobil 1 ATF change by flushing out 9 qts of old transmission fluid by disconnecting lower left(drivers side) 5/16 rubber cooler line. Did it one qt. at a time by starting my 93 EB, draining a qt. shutting it off and adding a qt. I have in all drained out 9 qts and put 9 back in. When I started it up and tried to put it into a gear, it will not eagage into a gear. Also, I can't touch any fluid on the dip stick. What is the problem? I sure need good help and advice fast! Thanks Mike
