CodePoet
- July 11, 2002
- Indianapolis, Indiana
- 1993 XLT
Thought i'd post up the latest change to the explorer. Two years ago at a club run I won a 9000lb mile marker winch. Well since the explorer SAS wasn't finished until last fall and other delays I just now got it mounted. I used a harbor freight mounting channel, cut down to fit between the frame rails. I then used some 2x6x.25 box steel and cut it into L brackets. Next I drilled it so that I could use the stock bumper mounting holes in the frame. I set it up so that the channel's back is around .25" from the radiator support so pretty much as far back as possible. I did need to trim the grill to fit the solenoid box. I't so far back I have to open the hood to get to the remote plug. Anyway here it is...i'm pretty happy with it all in all
