- February 16, 2001
- 43°48′48″N 91°13′59″W
- 91 4 do'
Last weekend I decided to break down my Warn M8000 winch that I had on my 94.
this thing weighed probably close to 50 lbs, but a lot of that weight and mounting depth was from the 2" receiver slide in mount that I designed my old front bumper around.
I rebuilt this winch last year with new solenoids and a motor so it's fresh and good to go. The cable was in bad shape so I pulled that off the spool. I stripped it off the receiver mounting block and then removed the box that has all the electronic controls to find that this winch is only about 20 lbs without a cable and fairlead. Mounting depth is less than 6" as is height.
I figure I can sacrifice putting 30 pounds or so on my front bumper without that having negative effect of my truck running in the whoops in exchange for the benefits of a winch.
So here is my plan
Mount this winch behind my grill by fabricating a mount between my frame rails.
Purchase synthetic winch rope (lighter, easier fairlead to work into my design)
Mount fairlead in one of two positions (shown below)
mount electrical plug in under hood
Hard-wire 2 switches into cab 1) toggle for in/out 2) on/off (basically a break in the line) safety switch. My hand controller has seen better days so I will probably just chop that apart to bring the controls into the cabin.
Which position should I try to mount my fairlead? Up high might be a little bit of a challenge for clearing my lights, I think a few tabs welded to the bumper should do the trip. Down low might put a put some premature wear on the rope unless I reel this thing in all the way, my front bumper has pushed down some hills while trying to find some jumps.
Any opinions/good places to buy the rope? I know BKennedy and Iz are running that stuff.
Any opinions of mounting the winch? I was thinking I could bolt it all in with some angle iron on the frame rails and a mounting plate across for a no-weld idea. If I went with the lower mount, I may look at welding the mounting plate at an angle pointing downward to make the "engage/disengage" lever easier to access through the grill.
I'd be curious to see how Matt (Rockranger) has this setup mounted behind his grill.
So here is my plan
