Just a quick note to say this thread still has life.
LOL I have a '02 Eddie Bauer Explorer and after reading the ENTIRE thread, as well as almost all of the "Chapter 10" document I found through this site, I'm going to start doing my own calculations as time permits.... (Combination of three jobs, a 10 year old son I see just a hair under half a month, a gf and an ex-wife, barely leaves me with enough time to pass gas in the morning as it is.....)
But, I'll endeavour to keep you all apprised of my progress along the way.
Oh, and one thing I KNOW I will be doing is a dry cell and not a wet cell...
Cheers!
Save your time and money for something worthwhile.
I don't get why people don't understand that HHO doesn't increase fuel economy. Petroleum is a hydrocarbon. In other words, it is made up primarily of hydrogen and carbon, and it was created from decaying matter, plants, sunlight, and millions of years of pressure and other such things to facilitate the bonding of those atoms into these energetic molecule chains. The energy to make petroleum is free, we already have petroleum.
When you split water into HHO, you are breaking a very stable chemical bond. This takes energy. You extract energy from the combustion of the HHO, which is basically a chemical reaction that forms the original chemical bond. You cannot get more energy out of that system than you had originally put in. This is a basic law of thermodynamics. Hell, even when you burn that hydrogen, you can only recover ~30% of the combustion energy in the form of mechanical energy, so the process is woefully inefficient anyway.
Really, people have been making HHO since 1789. The technology of it hasn't changed since then. You add electrodes to water and pass a DC current through it and it separates into hydrogen and oxygen. There is no magic here, no nothing.
To make matters worse, hydrogen is less energy dense than gasoline anyway. Basically all one does when they are running HHO is injecting a less energy dense fuel into a mixture so they can reduce the amount of petroleum they are using.... BUT... They could accomplish the same thing by just making adjustments to their engine and injecting hot air instead of cool air, and there wouldn't be the loss of energy that is used to inefficiently make hydrogen. There is a reason OEMs don't use this type of thing. Because it doesn't work. It only seems like it works to some people because they either, A: Don't want to admit they wasted their time and money, or B: Are confused about what is really happening in their engine. You can do the same thing more efficiently any day of the week. The only way to make running HHO into a cost effective operation that is more efficient than basic tuning and minor tweaks to your engine is to generate your HHO using solar panels on your roof.
And no, this is not some oil company conspiracy or anything else like that. We get tons of government grants, grants from private industries, even grants from oil companies to study alternative energy or engine efficiency. You know how many millions of dollars are spent on every tenth of a mile per gallon increase manufacturers get out of cars?
Also, just a note. It is WAY easier to run this type of system on a computer controlled car than on a pre-electronic injection car, that is unless you just want to keep your throttle valve on your carb tuned for a super lean mixture all the time to compensate for the brown gas that is flowing only some of the time...
