jcevans2
- November 2, 2011
- Raleigh, NC
- 99 Ford Explorer XLT RWD
O.K. quick update. I hadn't put the lift gate trim panel back on yet so I thought I would play around with the wiper circuit. I tried to figure out the little "twitch" in the wiper after the wiper switch is turned off. First thing I did was apply jcevans2's theory and ground the old park sense wire(vt/yel). That didn't stop the twitch, however it did happen quicker! There was no delay after turning off the wiper, it happened right away. I also tried using a relay on the park sense wire so that it was only grounded when the wiper was turned off. No difference there either. Another thing I noticed is that on the 98-01 wiper relay when the relay releases it goes to ground, but the 02-03 wiring does not. So I modified an old relay by removing the terminal that connects to ground. This had no effect either. So back to the drawing board on this issue. Need to put some more thought into this one and see if we can figure it out.
The reason why the 98-01 wiper relays go to ground is because the circuit is designed with two separate circuit actions. Electrical current flows through the wiper up relay, through the original 98-01 motor in one direction, and then through the wiper down relay to ground to complete the wiper up action. It could have been designed to go to ground in any one of several ways but routing it through the wiper down relay to get to ground, I assume, is probably the most efficient way to do it. This allows the same wires to be used when it switches over to the wiper down action. Now the electrical current can flow through the wiper down relay, through the original 98-01 motor in the opposite direction, and then through the wiper up relay to ground to complete the wiper down action.
The 02-03 relay does not need to go to ground on that side of the 02-03 motor because it has combined wiper up and down in to one circuit action. The motor has a diode in it so electrical current will only flow in one direction on the wire going into the diode when the relay is activated. When the relay is released, the current just stops flowing. This is why when you separated the relay terminal from ground it didn't have any effect on anything.
Good thinking though.
