jremington59
- October 28, 2009
- Watertown, NY
- 1997, 99 and 2000 5.0's
I dont think I understand what your saying. So I will clarify the issue. I have a 2001 Edge 2WD with Torsion bars. The front driver side upper ball joint is an adjustable two piece unit. You have one unit that bolts to the frame. Then you have the ball joint pressed into arms that bolts to piece one. The Issue I have is this. I can easily find the replacement piece for the ball joint pressed into the arms. The part I need to replace is the other piece that bolts to the frame. The piece that has the adjustment bolt in it. I took it in to a guy today and he told me that The one piece ball and arm assembly will be fine. The two piece is nice because its easier to align but the whole unit is not avaliable.
Did you look for it on Rock Auto?
