metroplex
- October 29, 2000
- Location
- Detroit, MI
- Detroit, MI
- 2018 Ford Explorer XLT
I have a 2018 XLT with the stock license plate light housings and noticed moisture always gets into them. I leak tested them and nothing comes out, so I am guessing the water is getting through the O-rings for the bulb connector which also twists into the housing (idiotic design). See the attached photo.
My 2017 Fusion uses the same housing, but its in an area that is a bit more tucked away (and a royal PITA to remove). Whereas my 2018 Explorer housings practically fall out once you push in that tab.
Has anyone else run into this problem with moisture? I checked the Lincoln MKZ to see what they are using, and they are actually using the LED version of what the Taurus uses. The lens/bulb housing is sealed, and the connector goes into the back of it. The Taurus just uses 2 screws for the lens, and there was a recall for fire issues due to moisture intrusion/shorting it out - The recalled housings have a hole with a goretex patch to allow moisture to vent out.
I lost one of the Sylvania LEDs (Zevo) due to moisture/water in the housing.
