DV8
- January 27, 2011
- Cedar Grove, WV
- 94 XLT
hello all, I joined this form in hopes i could get an answer to a problem i have.
The modulator valve on my 94 explorer, affectionately named dora by my daughter, was blowing tranny fluid into the engine and out the exhaust. I replaced the faulty unit with one from advance auto, which is an adjustable unit. without adjustments, it would make the 1-2 shift, downshift back to 1st, then back to 2nd. when it shifted into 3rd, it would pull for a few seconds, then just rev without pulling at all. Let off the gas for just a second, then it would pull fine. Overdrive pulls fine. cram the gas pedal to the floor at about 45, it downshifts, then the trans slips like crazy. I have adjusted the valve in small increments, and still have the same problem, which did not exist until I changed the faulty valve. any ideas? :exp:
