haktmal
- April 11, 2002
- Los Angeles, CA
- 98 Sport OHV
My $47 KKM - pictures
I get the PowerStack filter from IntensePerformance.com ($38)
I get this from Home Depot for $8.67
> Plumbing > Pipe Fittings > Plastic > Grate
6x6 Grate
SKU: #052063606408
The plastic grate has two opening pvc adapters so I had to cut the bigger one (3.5") to keep the 3":
Even though the larger adapter (3.5") is cut, there is still another one that is 3" left on the grate.
This is what get taken out of the grate. The grill is screwed out, and the 3.5" adapter is cut out.
I then remove the 4 nuts from the stock airbox.
And connect the PowerStack Air Filter to the grate. You see two circle? That's the outer adapter and the inner adapter. The inner adapter is connected to the air filter with the clamp.
Here is the other angle shot.
Closer
And closer.
I get my KKM for $38 + 8.67 = $46.67 dollars
6x6 Grate
SKU: #052063606408
Closer
And closer.
