vulture007
- May 28, 2005
- Seattle, WA
- 92 XLT
OK, I followed the break diary thread and replaced the front rotors, pads, slide pins, calipers, grease seals, rubber hoses and bled the system (92 Explorer 4wd). The glide pins are installed correctly and properly lubricated, the anti rattle springs are also good.
So I take it out for a 5 mile drive and the front wheels are still getting hot to the touch to the point where I cannot keep my hand on them. There is no smoke coming but it looks like the rotors are getting a blueish tint. There is no vibration when I apply the brakes and the calipers appear to be floating properly.
All I can think of is that:
a) the rear braks are not work well enough placing a higher load on the fronts.
b) the heat is coming from the front bearings (but I torqued those properly (finger tight) and re-greased them).
Is there anything else that I might be missing, is there something in the master cylinder that might be causing this. Are the front wheels supposed to get this warm?
Any help appreciated.
V
V
