RedDen
- March 14, 2012
- Calgary
- 2012 Explorer Limited
I swapped ACM between my Focus (with HD) and Explorer without HD. Explorer started receiving HD right away without any modifications, I was able to switch HD channels, there only thing missing was HD radio soft button on APIM, on right IPC display HD logo was appearing.Great! I have ordered an HD ACM for my Ex from Ebay. Should be here a week from Friday. Now, I was wondering about those amplifiers in the pic I put up in a previous post above (check it out). There are 3 versions of these 'amps' shown but, they do not show up in the parts list although you can order them from the illustration list from the site. For a little while, I was thinking they had something to do with the subwoofer which would be located in the right rear corner as the 'amp' is located next to it. Since it doesn't show up in the illustration for my Ex, I figured I didn't have one but, I was still curious as to why they have 3 different versions. So, I opened up my repair manual to see if I couldn't find out why. One of the amps is simply an 'audio amp' as described and the other two are 'DSP' amps. All of these amps are related to the Human Interface 4 units in different variations. I'm guessing that using one of the DSP amps with the HD ACM may allow the features like DSP for surround sound and EQ to function correctly as well as being an amp, even without the subwoofer. Knowing that car manufacturers will use the same wiring with all connections for all models, the connections for these amps may be in place and not used for the lesser systems. It may be worth pulling the panel off to find out. Of course, if anybody knows this already, that would be helpful to share.
Focus upon the swap lost HD receiving capabilities of course, HD radio button on MFT screen did just nothing.
I did not open ACM units, but Focus's one clearly marked as HD capable with its logo on sticker, Explorer has none so I think it is a hardware.
Now, with Forscan it is very easy to activate HD soft button on MFT
