nardbuster
- January 31, 2015
- 1999 ford explorer xlt
Driving with low fuel left me sleepless. I have not ever driven my 1999 5.0L XLT with gas at such a low level before. Then I put some gas from a questionable filling station.
The next day my 5.0L missed and showed no power. Two questions came to mind. The fuel or plugged filter / fuel pump. I went to a different filling station and added more gas. The idea add some better gas to mix with the bad gas.
A past experience came to mind. where I changed my plug wires and spark plugs. So I began there, New plug wires and plugs. Not the problem, changed the fuel filter, nope still runs poor, no power and interlopes to speed. Next idea was to drain the tank. I tried to use the fuel pump relay to something sparked.
I must have connected the the wrong terminals. Besides the fuel didn't flow.from the hose attached to gas line from the tank. Darkness came, I reconnected the gas filter and tried to start the 5.0. Gas does no longer make it to the gas rail... Has the jack lifted the car to a point where gas doesn't get to the gas pickup in the tank?
If the relay idea did not work. Can I put power to the power aft of the interia gas switch to get the fuel pump to assist in draining the tank through the line from the tank?
I have having a nightmare at this point......
Did I damage my Explorer by trying the relay trick to empty my fuel cell?
Tomorrow the sun will rise...I need some.ideas......
