kstrading
- June 25, 2003
- central ks
- 2009 Explorer XLT
A rear oil pan leak has forced me to pull the 4.0 on my 1992 Sport. While I'm in there I'll put in a new oil pump. Does anyone know the Torx size on the oil pump bolts? I'm also replacing the timing set. The manual recommends using a harmonic balancer installer tool when you go back together. Anyone use one? Thanks.
