92exp4x4
- February 5, 2003
- Covington, Kentucky
- 92 XL 2-door and others
My 93 4.0 van has had an intermittent CEL and pinging under load since I got it. It seems the engine burns about as much trans fluid as gasoline, which is probably part of the pinging issue. Anyway, I hooked up my scan tool this past sunday night and could not get any of the tests to work. The KOEO test never completed and the KOER test finally timed out and gave me a "no communication" error message.
I cleaned the connections, and inspected the plug.. only a tiny bit of corrosion on one of the pins. I tried it with the STO connector plugged in and not plugged in to the tool. I'm really not sure why its not working. Its not like the harness has been fooled with. This van is about as undisturbed as it gets. I feel like no one has worked on this thing at all over the years. No broken connectors, brackets, wire looms, etc, just lots of rust in the body. I haven't had time yet to test my scanner on another OBD1 vehicle, probably doing that tomorrow. I have not tried the paperclip method of retrieving codes yet either. The OBD2 function works great, just used it twice today, so I doubt the tool is defective.
Does anyone know about a fuse or common connection issue that could be causing this? I really haven't had a whole lot of time to mess with this yet, just hoping there could be a simple solution I'm overlooking. I was hoping to verify my lack of overdrive function and maybe a lean/rich code from the trans fluid ingestion (modulator).
