BlindViper
- August 23, 2007
- York, PA
- 2011 explorer limited
My 2011 explorer has/had p0171,p0174. So this morning I go out to look for the vacuum leak. Little brake cleaner all over the engine and nothing. I opened the the air box and the engine stumbled and picked up RPM. Checked the filter and it was dirty. So I run to the parts store, get a new air filter, carb cleaner, MAF cleaner. In the parking lot I changed the filter and headed home. 4 miles down the road coming to a stop sign the engine stumbled then picked back up. Then the gas pedal did nothing. So I put the trans it M to keep the RPM up. Then a few more miles it completely died leaving a stop sign. It would start then die, did this 20 times. Then I thought all I did was change the filter. So I opened the air box and left open it started. Got home turned it off then put the air box cover on and it started with out issue.
So I cleaned the MAF, throttle body, then sprayed all the vacuum/air box/intake connections with carb cleaner. Cleared the codes(P0174 P0171)and took it for a test drive. Its running fine I'll see if gge P0171,P0174 comes back.
What really concerns me is that the car completely died with no codes. Anyone have any thoughts?
