Doug Fraser
- August 15, 2005
- White Rock BC
- 99 Eddie Bauer
This is a great site - Thank You. I recently solved a 2/3 shift flare problem using the info posted here.
I now have another trany problem.
I am getting a P0741 code.
When this happens my 99 Eddie Bauer with 5R55E will not shift into OD. This happens intermittently (about once a week or twice on a 250 mile trip).
Code: P0741
Trany: 4R55E
Vehicle: 99 Eddie Bauer
Fluid: Amsoil Synthetic ATF
Valve Body: Replace about 10 months ago - 15K miles (purchased from Central VB)
Cooler: Factory installed external cooler
Mileage: 230 Km => 143k miles
Other: No towing or heavy loads - 10 miles to work.
About 10 months ago I had a new valve body from Central VB installed. This corrected the 2/3 shift flare problem. All new fluid Amsoil ATF was put in and the the filter was changed.
About a month ago I got the flashing OD light. The code is P0741. When the code is thrown the trany will not shift into over drive. I stop the vehicle, turn it off then restart and then proceed. The vehicle will then shift correctly into OD. This scenario repeats about one a week or twice on a 250 mile trip. There are no other shift issues.
I have put on about 20k miles since the VB, fluid and filter was replaced.
I have done a search and read through the threads. From what I can determine, the following are the recommendations to address the problem.
1 Replace fluid
2 check/replace TC solenoid - high usage part as it modulates the fluid flow
3 check/replace EPC solenoid
4 re sleave the TC valve bore - or replace VB
5 replace VB - done about 20 k miles ago
6 could be a wiring harness problem
7 replace TC - low probability of being the problem
Since the fluid is quite new and looks good (nice and red, no burnt smell), I suspect this is not the problem.
Here is my question:
Does a rebuilt VB usually have a TC solenoid or EPC solinoid replaced or are they just tested?
Given the situation as outlined, would the first step be to replace the TC solenoid and EPC solenoid and fluid change?
Is there any way for a good shop to test the solenoids? Since the problem is intermittent I suspect they could test OK one time and fail another.
Any other suggestions or steps I should follow?
Thanks
Doug
Code: P0741
Trany: 4R55E
1 Replace fluid
Thanks
Doug
