Power Window Switch | Ford Explorer Forums - Serious Explorations
Power Window Switch
jeffwhiteis
While I had the passenger side door panel off, I was prying the harness of the power window switch, and I accidentally broke the power window switch (the green circuit inside the switch got loose) When I reassembled everything, the switch wouldnt work and the window would not go down. The motor was not turning either.
My question is.... did I break the switch? I ask because the master switch on my drivers side will not role down the passenger side window either. If I broke the switch on one side, wouldnt the master switch role it down?
Is it the switch? Harness? Did I blow a fuse? What might have happened?
