trackerjoe
- August 23, 2011
- origin-Manchester,TN current-Parris Island,SC
- 2001 Volvo s80 i6
The openings for the 9007 bulbs were the right size for the threaded portion of the Mini's, but you will need to trim off the rear mounting flange that the lock ring connects to. The threaded mounting on the Mini H1's isnt long enough to clear the whole housing and still install the bulb. Basically its not just a bolt on, needs some modifications still.
outstanding! ill be home on the first and will start my DIY shortly after. sounds like itll be fairly simple. thanks for the heads up bluez.
