dcdyd
- January 7, 2011
- Eden Prairie, MN
- 98 Explorer
Yesterday, I completed my first brake bleeding for my 98 EX. Previous bleedings was done at the shop. In addition, I replaced front rotors. Before doing this, I had push backs when braking. Now the braking is so smooth and feels so good.
I do have one question regarding the color of the fluid that comes out of the caliper bleed line. I used a helper in pumping the brake. At the first several pumps, the fluid coming out was dirty, with air bubbles and was dark green in color. After about 10 times of caliper bleed on and off, the fluid became clear but still green. After 20 times, the fluid is still little green in color. The new fluid is somehow clear with little yellowish in color. So I wonder whether I need to bleed more.
For all four calipers, I used about 40 oz of the fluid. Finally I gave up and finished the work.
Is this normal? Or I should bleed more?
