jamazz
- February 3, 2014
- Drexel Hill, PA
- 2008 Ford Explorer 4WD
Hey guys.
I have a 2008 Ford Explorer Eddie Bauer Edition 4WD with a lighting issue.
The center console, where the radio, environment controls, and shifter are located, has some lights out. To the best of my knowledge, this is not a dimmer issue, as the gauges and radio lights are illuminated. What's not illuminated are the environment controls, 4x4 button, seat heater, and shifter gear indicator; the effected spot is between the center vents and shifter. I found a few pictures that detail how to take this panel off (Similar to gaining access to the radio compartment), but nothing specific to this particular problem. I'm looking to determine if the make/model of this vehicle does not illuminate this part of the panel as designed. However, if this part of the panel was intended to illuminate, are there any instructions on how to effectively troubleshoot and repair it? Perhaps the button assembly is back-lit with one or more bulbs, or, perhaps the button assembly individually lights each button? Not sure... Hell, it could even be a loose connection...which I hope it's not since I would assume that could even be more of a nightmare. But, I digress...
Any help would be much appreciated. My level of skill with cars is intermediate, but my electronics skills are much better. I repaired my washer after determining it was two bad capacitors. So, I'm hoping those skills will come in handy here.
This seems like an awesome community, so I have faith and am looking forward to hearing from you.
