texyank
- November 25, 2008
- '97 Sport
My radiator is leaking slightly at the upper transmission line. The radiator is completely full and the temp gauge stays where it always has. The coolant in the recovery tank is lighter in color than that in the radiator. The line to the recovery tank is open. I replaced the radiator cap thinking that maybe it wasn't opening and allowing coolant to flow to the recovery tank. I haven't driven it to check that out yet. Is there an o-ring or gasket where the trans line goes into the plastic tank? What else should I consider if the cap doesn't make a difference?
