After doing some research, I found out that the Raymart winches are made in Taiwan. Not sure who their designs are based from. It depends on how much use you'll get out of it when it comes to picking a brand. If your gonna be using your winch constantly, then definately look for another brand like Warn. Look at the Harbor Freight 9,000 lb winch. According to some reports on the web, they are made by Ramsey, the only reason they are not badged as Ramsey is because of the line speed. The slower line speed would definately help with the amount current running thru it. A 5.5 HP winch can easily take 65 or more amps to run effeciently. The HP rating on the winch motor relates to the line speed. The higher the HP rating, the faster the line speed.
