cfkane
- July 26, 2004
- Denver, CO
- 93 XLT
Try the diagnostics before you jump right in and replace the pump. Bad vapor return can cause a vacuum in the tank. How about a fuel filter that is plugged. Did you check to see if you were using Ethanol, most states require labeling on the pump. What did the fuel pressure test look like? Does the problem happen with the tank empty or full? All of these items can result in the same symptom.
On the subject of fuel pumps there are about 8 different manufacturers in use out there. In the case of the aftermarket most of those will be repackaged from one of the major vendors. I would not cut corners based on price as you do not want to do the pump replacement in the near future due to poor quality components. Get a pump that is of the same design as the OEM one, in other words take a close look at the pump to compare new vs old. You want the same capacity and pump size. Lots of smaller ones are out there that meet the specs they just do not last as long.
