Mutt#1Butt
- March 11, 2012
- Virginia
- 2001 Sporttrac
put rear cab window down, wont'go back up, other power windows work, pulled plug at motor, went all 8 plug points to ground-no power (12V), have pulled the dash panel to access swith but don't know the wiring schemetic here. can I try a temp power feed here or check the switch operability - window wouldn't go up or go up to vent position pushing button in, wouldn't go up holding switch in place ?, can I go to the plug at the motor and try a temp pwr feed there? I didn't pull the motor from the housing because I got no power there when checking (with ignition switch on and operating window switch up).
As you can probably tell, I'm a novice. Can someone point me in the right direction pls? Thanks
