DavidEBSmith
- January 26, 2004
- Chicago, IL
- '07 Mountaineer Premier
(I couldn't get the PCM connector to latch but it was just that I wasn't pulling the gray lever back far enough)
Now that I figured that out, I'm trying to replace a contact on the PCM connector where the wire into the contact broke off. I watched the videos here and have a tiny screwdriver to push the latch on the connector but the problem is, the wire is broken off flush with the back of the connector so when I push on the latch from the front, I have nothing to pull on from the back. And from McGyvering fixes over the past several years, the broken-off piece of wire is absolutely wedged in there.
Any ideas on how to remove this broken off wire & contact?
