Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
To keep a long story short... I had to splice my fuel line just after the filter. I used a Dorman repair kit with the nylon tubing which includes a 5/16 double sided barb. When is installed the barb in the Dorman hose it slid in very tightly and sealed just fine. When I went to slide the barb into the older fuel line it seems to have expanded over time. I thought I’d just buy the entire fuel line from the filter to the engine but there are none to be had. So I was thinking about pulling the entire fuel line out as it doesn’t appear to be attached to anything other than the connecting points at the filter and the fuel rail. I noticed where the braided nylon fuel line goes into the metal tubing is crimped about a 1/2 inch. I’m assuming that where it is crimped there’s got to be a metal tube that the nylon tube will slip over. I was thinking I’d pull the whole thing out, cut off the crimped part and install new nylon fuel line in its place. Has anyone ever done this before or are there any reasons this wouldn’t work? Any input will be helpful. Thanks!
