- February 2, 2002
- 1998 Mountaineer AWD
What are your actual fluid temps? I wouldn’t bypass it without adding additional cooling.I think that I was correct. Old double flair style versus the new style. Get up under the truck and where one line turns to go towards the radiator and cut it leaving yourself enough of the line going towards the transmission to carefully by hand straighten it towards the bumper. There is another line coming of of the trans cooler mounted in front of the radiator that turns to go to the built in cooler. Cut it. Now take an appropriate size piece of hose, 3/8" sturdy hydraulic hose and two clamps to entirely bypass the radiator cooler. I used a phillips head screwdriver and stuck in the end of each line and rotated it around to flair the ends a bit to help keep the hose from wanting to slide off. Now your built in cooler is bypassed.
I live where it gets up to about 105 F heat index and I don't tow often so the factory cooler seems to be plenty. If you live in a desert you may need a bigger cooler. You can buy a bigger cooler and it is a bit overkill, but I have seen people turn there AC condenser into a trans cooler. Bypassing the radiator "built in" cooler worked for me !
The Dorman line is probably just wrong. They are a garbage.
