96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
Yes, I am replacing all brake (hard lines). All lines are rusted but some are in better shape then others. Regardless, the entire hydraulic brake system was flagged in MD inspection to replace.
The lines and fittings from the ABS closer to the hood and master cylinder are in good shape. Once they go below the master cylinder they are rusted ( and what was flagged in inspection.) So I will have to remove the lines to the ABS as well.
Will this introduce air to the system regardless of keeping the reservoir filled? Confused. There is 1 line from the ABS control module direct to the master cylinder. Then 4 go down towards the left caliper and spread out from there.
I was going to bleed and replace one section at a time starting—rear axle, rear left/right hoses—then passenger front line, left hose, then right and hose, then 4 lines going up to ABS, then master line to ABS using a vacuum hand pump bleeder.
How can I do this without introducing air into the ABS module?
I plan on starting this weekend and don't want to damage the ABS. I did read in the Haynes the ABS warning when bleeding but only on 96 and earlier.
If you can plug the outlets at the ABS fittings as soon as you remove the line you won't get air in the ABS system. I don't know what the 98 has but you can get M10 or M12 brake fittings (I guess that is what the internal thread is??)that adapt to standard lines. You can probably fabricate some sort of plug with a short piece of line. The trick is to keep fluid in the master cyl at all times.
But again, even if the fluid runs out (which I've done many cars) you shouldn't really have an issue if you do a full bleed. You will never damage the ABS like this, in the worst case a dealer will charge you an hr of labor to rebleed the system. You can also activate the ABS a few times then rebleed if the pedal is spongy.
What would happen if it failed on the road and the system went dry? Then you couldn't prevent it.
