mikepier
- December 24, 2008
- Long Island, NY
- 99 XLT
15 XL
Mike,
Just a word of caution: I wouldn't blindly replace things without being absolutely sure. Based on your description, I would first check the "air" side of things (air filter, MAF, IAC, vacuum leaks, etc.). These things are easy to get to and relatively cheap to clean/replace. In my experience, bad sparkplugs will cause driveability issues along with a rough idle, too (low/no power, skipping, etc.). I haven't heard of spark plugs only causing rough idles and nothing else (I could be wrong here, at least it hasn't happened to me).
A word on CELs: Even though the CEL is not lit, your PCM may have codes "pending" (that is, your computer isn't sure if the issue is a constant problem). If a code is "pending" for some time, your CEL will come on. I would stop by your local auto store and borrow their handheld scanner to see if anything is pending.
Good Luck!
ERUSH
The air side as far as I can tell looks good. New air filter, I cleaned the MAF and IAC, and I don't see or hear any leaks. But I know what its like to replace things and it does not fix it. I do not want to fall in that trap.
So I'll keep it in mind.
