eXploderNoMore
- June 19, 2008
- ABQ, NM
- 1996 Eddie Bauer
The only way to test an EPC or TCC modulated solenoid is to connect a special tool to it which simulates the actual modulated signal to see how the solenoid reacts. I suspect that the swapped valve body might have old solenoids, and possibly other issues. WWW.CentralValveBodies.Com gives members of this site a discount (I don't know the actual percentage), and is capable of testing both valve bodies for you. They will either tell you if they are good or repair them for you. I would suggest this if you are not comfortable rebuilding the valve body yourself or letting an average shop do this kind of work.
I will look into this, thank you!
