Josh S.
can't kick the habit
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Yo-I have been soing a lot of thinking/asking around about various options that I have to make my suspension awesome. Here they are, let me know what you guys think:
1. This is probly the easiest/maybe least expensive...First is to get the d35 cut and turned and widened. This would get rid of my crap superlift dd brackets and widen my track a bit. In addition to this, throw on some bilstein 9100 coilovers or kings, w/ air bumpstops, extended radius arms. This would be excellent for desert running, and good for rockcrawling, but not as strong as it could be, due to the d35.
2. This would be to do the same as above, but instead of the widened d35 axle, It would be turned d44 beams out of a f150. This would be a lot stronger than a d35, and would be kick ass for desert stuff, as well as rockcrawling, so I've heard. This option would be ideally coupled with coilover setup with sexy radius arms and the like ORrrr, the cheaper(but still hell ass expensive) go with the autofab d44 beams, and a triple shock setup on each side in the front. This would be normal shocks and eibach coils, but it could still take a pretty hard beating.
3. This option is of course the infamous straight axle conversion. This is tempting. It would be real strong which is great, good for crawling I guess, but what about desert running? The ttb is better for this yes? I enjoy going fast in the desert, but am extremely limited in what I can do now, because of my current setup. I have a cracked, rewelded, cracked again axle-pivot drop down bracket that I have to baby, and all the other stuff isn't so hot either.
I of course can't do all this stuff at once, but I want to get a better idea of the pros/cons of each method, what each is good for, cost factor(again) and also any other recomendations that others may have. Thanks
