84FLH
- February 14, 2016
- 2000 Mercury Mountaineer
Donalds;
Thanks. Great picture. Shows what I needed to see.
Turdle;
Thanks. I reseated PCU connector few nights ago. Pins and connector housing were clean with no grit, dust, grime, dirt inside. Same for female side of connector. Reseated connector 4x then started engine. #3 miss was gone. Rev'd engine to 3k rpm smooth with no misfire. Didn't drive vehicle, though. Started vehicle 5am following day. Misfire was back.
CEL has been on solid with P0303 and P0171 for past week. CEL often flashes going up hills to/from work. I pull over, shut off motor, then restart motor. That clears the flashing CEL.
Stopped at parts store on ride home from work today. When I started vehicle after leaving store the miss was gone. Drove 3 miles to a local mechanic to ask a few questions. When I started engine at his shop the miss was still gone. Drove 2 miles home and parked it. Miss was gone when I parked.
I had been losing signal just before #3 injector (noid light would go off and stay off). When signal lost, misfire happens. When signal present there's no misfire. So I'm thinking wiring or PCU trouble.
Am 3/4's way through full tank with Lucas injector cleaner. Also added 5 oz Seafoam to oil to quiet intermittent noisy lifter. That noisy lifter might be timing chain noise, though at bottom, front, passenger side of motor.
Turdle;
