Josef86
- March 10, 2006
- Merrimack, NH
- 2003 XLT
About how much of a gain would you see running tires at 40psi rather then running them at the psi the door sticker tells you?
On my 03 it tells me to run them at 30 in the front and 35 in the back. I am considering going 35 in the front as well.
One thing I have noticed is try not make a bunch of small trips, or if you need to make more then one trip try and do it when the engine is still warm. When you crank a cold engine it only uses a few sensors and guesses how much fuel to use. When everything else warms up and all the sensors kick in it will use less fuel. Some one else can probly explain this better.
